I was wondering if anyone knew what would be the best way to compliment vehicles from the 1:35 scale and figures...? I was wondering if it would be 1:48th because it seems to have more aircraft available than any other scale. However, I would like to have detail and lots of it when I'm making a model. Any other scale like for example 1:32 is hard to find a large variety of in that scale. (Maybe not that much detail, but enough to give it a good feeling.)
Aircraft Questions ;-)
GuestTags: None
Yeah...is a pity that there isn't planes at 1/35....only a few ones by the moment.
1/48 is so small for a dio...my opinionops:
And at 1/32 you will find an interesting figure range... -
I think that 1/32 scale, being arithmetically the closest to 1/35 is the one to use. There is of course a difference which for figures equates to an average bloke (say 5'9" tall) becoming a tall bloke (over 6')
1/32 is an ever expanding scale for aircraft models, more and more are becoming available. It is a big scale for dioramas. When you put two or three models together they take up a lot of space.
SteveComment
The difference between the two scales of a six foot man. 1/35 51 mm high 1/32 is 56mm high. Or in old maths one quarter of an inch difference.
With a little ingenuity it may be possible to extend the figures. Extend the torso or upper or lower legs.
One to 48 there is relatively no problem.
http://www.hobbylinc.com/cgi-bin/s8.cgi?cat_s=SE&tag0_i=266&p=3 found these (USA site) so there are some 1/32 around.
Take a look on the Airfix site they are expanding. http://www.airfix.com/figures/1-32-scale-figures.html
LaurieComment
Originally posted by \Yeah...is a pity that there isn't planes at 1/35....only a few ones by the moment.1/48 is so small for a dio...my opinionops:
Originally posted by \I think that 1/32 scale, being arithmetically the closest to 1/35 is the one to use. There is of course a difference which for figures equates to an average bloke (say 5'9" tall) becoming a tall bloke (over 6')1/32 is an ever expanding scale for aircraft models, more and more are becoming available. It is a big scale for dioramas. When you put two or three models together they take up a lot of space.
Originally posted by \The difference between the two scales of a six foot man. 1/35 51 mm high 1/32 is 56mm high. Or in old maths one quarter of an inch difference.With a little ingenuity it may be possible to extend the figures. Extend the torso or upper or lower legs.
LaurieComment
1/35 aircraft:
The Fieseler Fi156C-3/Trop Storch (Tristar) or you have also the Piper Cub L4H "Rosie the Rocketer" (Bronco)Comment
Originally posted by \1/35 aircraft:The Fieseler Fi156C-3/Trop Storch (Tristar) or you have also the Piper Cub L4H "Rosie the Rocketer" (Bronco)Not a Bf109K4 or anything
Originally posted by \1/35 aircraft:The Fieseler Fi156C-3/Trop Storch (Tristar) or you have also the Piper Cub L4H "Rosie the Rocketer" (Bronco)Comment
