And now for something completely different.........
Posts
    ..........a Woody!
    1/25 scale kit from Monogram
    the kit looks pretty good . The flash looks minimal and the decals have the wood grain for the sides on the sheet along with some assorted window graffeti. Started dry fitting and have found a mis molded axle end.
    The frame is were I'm going to start . The crossmember support has some alignment issues. No matter how hard I tried to line up all the little holes it just moved the problem to another location. This is going to create some tedious sanding later,ah well wacha gonna do.
    I just did the best to minimze it and press on
    • 18271
    Now when I saw the title, I was half expecting to see you building a Spitfire. But a CAR! I didn't see that one coming!
      That looks cool shame you cant make the wood parts yourself.
      I'll be watching this one
        Thanks Ian it was a surprise to me too lol. A Spitfire ya say hmmmmmmmmmmmmm. John thanks ,I might try the technique for 'painting' on the wood grain depending on how the decals look after they 're on.I've started to putty and sand the frame Here you can see the gaps and poor alignment of the holes in the crossmember support
        First application of putty
        I used some acetone on a 'Q' tip to smooth it down to minimize sanding.
        The frame almost ready for the fiddly bits
          • 22771
          Looks like some hard work coming your way Trey but its coming together nicely so far
          • yak face
            • Jun 2009
            • 13842
            • Tony
            Great looking kit trey, even with the slight problems! Are you going to do it stock or rod it? tony
              Thanks Ian ,thanks Tony, I'm going with a slightly rodded daily driver look.I fixed up all the fiddly bits and ran some brake lines using copper wire
                Frame has a base color now
                I think a moon roof is in order so here goes
                Finished Mill ready for instal. I added some wiring and tubing
                  • 18271
                  Moon roof. Funny that over here we call them sun roofs...
                  Nice motor.
                  • simontie
                    • Jan 2010
                    • 1506
                    looks good you sure do like a challange - can't wait to see the results - good luck
                    simon
                    Why is common sense not so common?
                      Thanks Ian and Simon. I'm plugging along with the body. Decided to remove most of the chrome trim to clean up the body and make it less busy. I'm also going to remove the front marker lights and replace them with some smaller units,here one side is done
                      Next the chome trim,before
                      after
                      and the Hood before
                      after
                      the finished body is almost ready for paint
                        Nice work Trey. Looks like our version of the Moggy Shed. Morris 1000 Traveller, my bad had one when i was a wee boy lol. Cant wait to see you do your magic on this one.
                        Andy
                        • yambam26
                          • Mar 2011
                          • 622
                          Nice work there, Really liking the smoothed bonnet
                            Thanks Andy,had to google Morris we do'nt have many this side of the pond,you're right real strong resemblance. Thanks Ben appreciate that! I had decided to leave out the back seat,hey its a Beach goin machine after all. This also gave me an excuse to scratch some items and have some fun with it. First a go at a cooler
                            throw in a few beach towels and we're almost ready,going to add a few more smaller items later,maybe a boogie board,ect
                            also got the running gear mounted and plumbed
                            and a little more progress on the body
                              I finished up the scratched exhaust,I just had to do some duals with the old school 'Cherry Bomb'mufflers
