GWP Ruins dio constructed from home materials during lockdown.
Posts
  • rtfoe
    • 9094
    Hi Guys,
    In the midst of constructing My Kure Harbour and ships I saw Scotties bridge done with compressed foam and decided to use that material and some Italeri church buildings left over in my stash. There was a ready base and with that I modified the construction of the kit buildings and mated it with a carving of polysterene arch. I will let you in on the story if this progresses further than it is now...
    This didn't take long surprisingly as the bricks were glued over the rough carved arch. It would normally take me ages just to putty and sculpt but the arch was done in a couple of hours. The rest of the Italeri buildings were stacked, glued and the backs filled with polyfilla and one side of the base was supported with a styrene block and coated with plaster...
    The bricks were coated with diluted plaster once the glue cured... the sides will also be bricked up, I only plastered to get rigidity to the frame.
    The back too was carved and bricked. The black is card that I usually stick onto cut offs...
    Finally all the components are stuck, engraved and ready for primer. Whatever is not terracota in color are add ons or fabricated...
    With the white primer it roughly looks like one building. I'll be adding a water feature from Italeri in the corner and perhaps a Firefly parked just under the arch.
    Hope this progresses further...I have a bad habit of jumping from one build to another. If you wanna know what this is going to turn out, stick around, there's no place to go anyway with the lockdown. :smiling2:
  • scottie3158
    • 14214
    • Holbeach
    Richard,
    That looks great, now the primer is on it all looks as one.
    • Fernando N
      • 2448
      Very nice Richard :thumb2:
      • Mini Me
        • Jun 2018
        • 10711
        That turned out nice Richard, I think it's a go...will stand by for further developments.
        • The Smythe Meister
          • Jan 2019
          • 6248
          Looks great Richard :thumb2: ,
          I`ll definitely be following along!
          Andy
          • rtfoe
            • 9094
            Thanks guys, really appreciate the response. The Firefly is a kit that I will take out of mothball. It is one of two that I built up ready for such dios. Heres a glimpse of it.
            It's an old Verlinden hull which needed some modes and a new barrel from brass and putty.
            • SimonT
              • 2824
              Very nice Richard
              • Neil Merryweather
                • Dec 2018
                • 5198
                • London
                That's looking great, Richard.
                1/35 scale, I assume?
                • adt70hk
                  • Sep 2019
                  • 10416
                  Looking very good indeed on the ruins.
                  Well done.
                  • rtfoe
                    • 9094
                    Thanks Simon, Neil and Andrew, yup , back to the good old 1/35 scale...even so I still got a cracking headache after priming. Must have been the constant and non-stop hours at the bench. I just couldn't stop...fun when you're on a roll...and suffer later.:smiling2:
                    Here are some more snippets of the Firefly... I lost the main hatch covers so scratched some and added grab handles and levers plus head padding.
                    I used some of the Verlinden etch and made my own periscope guards from fuse wire. The extra stowage from plastic card is attached to the armoured bussle.
                    I don't remember why I took the rest of the pictures for...perhaps to show how I made the periscope guard base. I'm sure by now many would have done a better job.
                    Close up of the extra stowage can...very basic. I don't think it was armoured so will make some dinks and damage with my motor tool.
                    Another shot...perhaps I am suppose to add periscopes to the holders...now I remember I stopped when I had to cut some strips to make them and got distracted as usual.
                    I don't know how accurate the Verlinden hull and turret are. The turret seems like the older version that will need the extra aplique armor to the right side. With all this lockdown time I may re-visit the Afrika Korp Dio. Ta for now.
                    • Steven000
                      • Aug 2018
                      • 2830
                      • Steven
                      • Belgium
                      That's some lovely detail Richard! :thumb2:
                      Looking very good
                      Steven
                      • JR
                        • May 2015
                        • 18273
                        Richard, putting your time into a fantastic building, merges perfectly with the plastic one on the right. That stone work is top notch both is size and texture .:thumb2::nerd:
                          Excellent modelling Richard :smiling3:.
                          • minitnkr
                            Charter Rabble member
                            • 7547
                            • Dayton, OH USA
                            Some excellent progress. Love the wire work. PaulE
                            • rtfoe
                              • 9094
                              Muchos gracias Steven, John R and Ralph,
                              I photographed the Fireflys before I mothballed them so have got them mixed up. The set of photos are actually both the Fireflys I built in tandem, one is the Verlinden hull and turret on Tamiya bogies and the other a Dragon kit which I'm not sure if it's the corrected version. I only noticed the difference in plastic and resin so the first is Verlinden, the second , third and fourth are Dragon and the last Verlinden. Much apologise. :flushed:
                              The one that I'll be using is the resin Verlinden kit.
                              As for the building I'm quite chuffed that the merger worked. I will be hiding the not so nice parts with parasitic plants usually found creeping on old buildings.
