Ok .. i'm confused here .. this is a detailed build , full engine / gearbox parts but the bonnet .. you have the option of glued open or glued closed .. why go to the detail of building and painting the engine when i want the bonnet to be open or closed .. there is no option for this in the kit ? Do i have to try and fabricate very small bonnet hinges ? can i buy these ?
I want bonnet open or closed on a pivot to show off the work .
This is an AK kit .. very detailed and far above what i have attempted so far ..
First off .. the spruces need a dam good clean .. something i've not come across with Tamiya kits .. in short .. heavy oil contamination that ruined the primer base .
Basic chassis and partial engine build completed so far ..
I've been using the glue as a filler on the figures .. is there something that's better as the gaps are pretty small and glue seems to do the job ?
Once again .. my images are not the correct way upwards .. i'm doing something wrong here but am unsure on how to fix this .. i use my phone for these images .. i use paint to rotate , resize and yet they still show sideways .. sigh .
Thank you for your time .
