1/35 Sherman M4A3 Calliope
Posts
    Hi I'm going to try and build the Sherman M4A3 Calliope, there will be 1-2 upgrades along the way.
    Parts.
    Ref.
    [ATTACH]319796[/ATTACH]
    [ATTACH]319797[/ATTACH]
    Most of the Sherman Caliopes had is large box fitted to the rear to store the stowage away from the rocket wash.
    [ATTACH]319798[/ATTACH]
    Roccket deflection shield to prevent the wash from the rockets entering the engine through the grills on the engine decking doors.
    [ATTACH]319799[/ATTACH]
    [ATTACH]319800[/ATTACH]
    [ATTACH]319801[/ATTACH]
    Thank you for looking in.
    Pete.
    A bit of background.
    The Rocket Launcher T34 (Calliope) was a tank-mounted multiple rocket launcher used by the United States Army during World War II. The launcher was placed atop the M4 Sherman, with its prominent vertical side frames firmly anchored to the turret's sides, and fired a barrage of 4.5 in (114 mm) M8 rockets from 60 launch tubes. It was developed in 1943; small numbers were produced and were used by various US armor units in 1944–45. It adopts its name from the musical instrument "Calliope", also known as the steam organ, which had similar parallel or clustered pipes, and which had historically existed on steamboats of the Mississippi River in the United States, or as is more commonly known and associated with traditional "circus music"
    Variants
    • Rocket Launcher T34 (Calliope) – Version carrying 60 4.5 in (114 mm) rockets in arrangement of a group of 36 tubes on the top, and a pair jettisonable groups of 12 tubes (24 tubes of jettisonable groups) on the bottom (Not jettisonable from M4A1 Sherman variant).
    • Rocket Launcher T34E1 (Calliope) – Same as T34 but groups of 12 jettisonable tubes replaced by groups of 14 tubes.
    • Rocket Launcher T34E2 (Calliope) – Caliber of rockets increased from 4.5 in (114 mm) to 7.2 in (183 mm), number of tubes remains at 60. Saw combat in 1944–1945.
    [ATTACH]319804[/ATTACH]
    T34 Calliope
    Type Tank-mounted rocket launcher (Rocket-Artillery Tank)
    Place of origin United States
    Service history Wars World War II
    IProduction history Designer Victor Hawkins
    Designed 1943
    Specifications
    Main
    armament
    60 × 4.5 in (114 mm) rockets (T34),
    64 × 4.5 in (114 mm) rockets (T34E1),
    60 × 7.2 in (183 mm) rockets (T34E2)
    Pete.
      Hello Pete,
      Have you ever thought of going in for resurecting the dead? I can remember when this kit came out originally or was it Monogram. Can I pull up a chair and have tea and sarnies ordered while I watch your magic work on this.
      Mike.
        • 22771
        Looking forward to seeing what you do with this one Pete.
          Monogram had a 1/32 scale M4A1 (75 mm) with the Caliope launcher. Italeri’s is at least of the right type of M4
            Originally posted by Jakko
            Monogram had a 1/32 scale M4A1 (75 mm) with the Caliope launcher. Italeri’s is at least of the right type of M4 :smiling3:
            I thought my memory would not let me down, I think back then the only word we knew was Sherman, the variation was open to discussion. And I am sure it came with 'figures' and a diorama leaflet by Shep Paine. Mike.
            • stillp
              • 8096
              • Pete
              • Rugby
              I built that in the 60s, it was really enjoyable!
                Hello Pete,
                Mike.
                Hi Mike yes and my court case is in two weeks, as for the kit the box hes 1996 on it, the brew is on and have order doughnuts.
                Pete.
                  Hi Ian don't expect too much but I'll do my best.
                  Pete.
                    Pete.
                    Mmmmmmmmmm! on my way.... Mike.
                      Hi I'll be using or adding Archer casting decals and some of the photo etch below.
                      Will be adding frontal sandbag armour.
                      Pete.
                        Got all the bogie unit, drive sprockets and idlers built and will do all the mods tomorow.
                        Pete.
                          • 22771
                          The bogie units look like mini motorbikes of judge Dredd.
                          • JR
                            • May 2015
                            • 18273
                            Front seat with donuts please Pete.
                            Love this type of model.
                            John.
                              Good description and it gives me a idea :thinking:.
                              [ATTACH]319990[/ATTACH]
                              Pete.
