1/35 Trumpeter Panzerkampfwagen. VIII Maus Build
Posts
    • 15821
    Hi Alex
    I would go with Tim's idea. You do need a fine razor saw. I think a very important part of modelling is thinking of ways to sort problems. I usually try bad language, it rarely helps but I do feel better.
    • Ancientmariner
      • Feb 2018
      • 859
      #32
      Originally posted by Jim R
      Hi Alex
      Sign of a true great isn't how well you do it, it's how good you can make a messed up bodge job look :smiling2:
        • 18959
        I always think that’s what you pay for when you get a professional in to do DIY type work at home. You pay for knowledge!
        • NicolasCage
          • May 2020
          • 41
          #34
          After a week or so away, back at work. Wheels prepped and other parts undercoated. Anyone have any suggestions as to reduce clouding when using matt varnish over black?
          • NicolasCage
            • May 2020
            • 41
            #35
            Inside of the turret all complete.. shortly to be hidden entirely from view when the outer part of the turret is put over it. Hence why I can’t be bothered to put much read any painting detail into this part.
            • Gern
              • 9259
              #36
              Hope you don't mind a bit of advice Alex:
              For the love of all the Gods get rid of that pocket knife and get yourself a decent craft knife with scalpel blades!!! That will absolutely halve the time you spend on clean-up of flash and sprue attachment points.
              PS Good work so far, and I'd follow Tim's suggestion for your sprocket repair. A nice, clean square cut will make it much simpler to reattach the parts.
              • NicolasCage
                • May 2020
                • 41
                #37
                yes a proper craft knife with scalpel blades may well be in order… my pocket knife would struggle to cut cheese…
                Sprocket repair is done, many thanks for the advice all!
                • Gern
                  • 9259
                  #38
                  It'll be the best modelling investment you'll ever make! Get the best you can afford - it will be worth every penny.
                  • dalej2014
                    • Aug 2021
                    • 507
                    #39
                    Seconded; heartily agree. I couldn't believe my eyes on viewing the pictures.
                    And what a build!? You seem to be doing very well considering how detailed and daunting this looks. Following.
                    • NicolasCage
                      • May 2020
                      • 41
                      #40
                      Slowly coming along - only a dry fit at this stage but finally looking like a tank!
                      • NicolasCage
                        • May 2020
                        • 41
                        #41
                        Been a while since my last post… turret camo done and needs weathering. Rest of it has had base colour with highlighting/shading
                        • NicolasCage
                          • May 2020
                          • 41
                          #42
                          Turret pretty much complete.. kept the weathering subtle - also tried dry pigments for first time and came out ok (may add few more patches of this on the turret)
                          Made a c**k up of the camo on the sides so re-doing this
                          • NicolasCage
                            • May 2020
                            • 41
                            #43
                            Added some chipping effects on the turret..
                            And one track is now complete with rust/dirt effects and part of the engine is complete!
                            • NicolasCage
                              • May 2020
                              • 41
                              #44
                              Been ages since my last post.. it’s almost complete!
                              Just need to: add interior (which is scattered around in the background)
                              Mend some of the tracks (they were a complete s**t to fit but kinda got there)
                              Add decals
                              Weather side panels.
                              Pleased for my first effort but needs improvement.
