AFV Club 1/35 Centurion Mk5/2 with 105mm gun
Just seen this Mick, one of a very small list of post WW2 Tanks that i actually like!!:hugging-face:
.... I`m in mate,looking forward to seeing what you do with it.:thumb2:Comment
Cracked on with the suspension and a few other additions to the hull. Leaving the wheels off for now to make painting easier. A couple of quite fragile bits gone on the back but invisible repairs carried out on them, looking at the bits to come I’m certain they won’t be the only ones to require surgery
[ATTACH=CONFIG]n1220231[/ATTACH]
This is not a disaster as you can remove the arm and drill out the hole and use a piece of sprue or drill through before removal and then once removed use a piece of metal rod to secure and adjust.Comment
Mick, did you glue in the adjuster for the return front idler wheel? Please say no! You can use this to adjust the tension on the tracks - sorry but this slipped my mind.
PHEW!!!!! Sorry I forgot to mention this, I got caught out once with it and on every one after it was a major point I should not have forgotten. But the one I forgot went to the Nationals and I convinced another modeller that the AFV Club one was wrong and mine was right.... Emailed him later that day to correct my mistake - good job I know him.....Comment
Another thing to keep in mind with AFV Club is that sometimes larger, flat parts have very big semi-circular nodules on the underside from the ejector pins. Usually you can just leave them be, but some get in the way for fitting the part where it’s supposed to go. Better to always test-fit them to make sure whether or not you need to cut some of those things off.
Yes, fit isn’t Tamiya-like (though it’s never actually bad), but then, AFV Club do give you all the detail that Tamiya thinks is wasted on its customersComment
