Hi Mick........good of you to drop by and thanks for the nice comment. I hope This won't need stitches, I'm having enough difficulty just getting the CA and Cement where I want it. :rolling: Rick H.
1-87 Scale Luftwaffe Airfield Water Bowser By Rick H.
Yup.....RH drive was the order of the day on these early Military rigs....a couple of years earlier and you'd be seeing a chain drive under this crate. Thanks for stopping by......currently working on the top hatch for the tank and am hoping to get the tank railing fabbed up and the hose brackets as well..........we'll see.
Rick HComment
That is rather nice. That anyone builds a kit in this scale amazes me. That you can scratch build one!!! In my stiff fingers it would end up either crushed of dropped (at least five times!).
Great work.Comment
Thanks Paul, it's bigger than it looks.....over an inch long and half an inch wide. Made a small form block out of plastic and formed each end around it trimmed the excess rod, squared it up and butt soldered the end.....kept me out of the Missus hair for a couple hoursRick H.
Finally got the hose brackets made and installed..........the real challenge however, turned out to be the aluminum fitting on the hose end that coupled it to the valve......made that a total of 5 times, feeding the "Carpet Monster" 3 out of 5 and destroying the 4th during manufacture. Last item will be the fill valve and spout on the live end of the hose.....think I need a "Nap".
Rick HComment
Rick. Nice updates that Hose reminded of the Red Worms I use to fish with itโs getting that time of year you knowComment
