My granddaughters carousel
I made the hollow central column and origionally dismantled a cordless screwdriver which I used to drive it around but this turned out to be far too fast and difficult to control the speed, it was later replaced with a geared motor running at 12rpm further reduced with the pwm signal from the arduino which I also programmed to start and stop it slowly.
I think it was a decent attempt considering I only had a rather beat up Drummond round bed lathe at the time (now modified into my milling machine)Comment
Next was making the carriages and getting really lucky with a job lot of horses meant to be made into dolls house rocking horses
The carriages where painted up and attached to the platform
and then I turned my attention to making the horses gallop
These gears took me an age to figure out, mostly the crown gear that you can just about make out under this mock up. In the end I found a meccano crown gear that suited my needs and made the smaller gears myself (By this time I had brought my uncle's Harrison 19" lathe which made everything so much easier).
Finally for today a picture of it all placed
The outer ring for this top was my first ever foray into wood steaming, I probably should have had it thinned a bit more but it worked so..Comment
Really busy day today with mostly boring stuff :anguished: but heres the next installment:
Once I had the mechanics sorted out I turned my hand to painting, I stared off by finding a suitable font for the lettering around the top and printed them out.
I then traced this onto the models top
my brush work isn't the best but at least no one can accuse me of cheating here :tears-of-joy:
I then thought this looked a little bland and needed a bit of bling
Which I created by mixing various colours of glitter with pva glue and painting it on.Comment
So once I was happy (or content that I had it looking acceptable at least) with that painting I turned my attention to the lighting
It soon turned into a right birds nest of wires and if I had planned better I could of made it much neater but that was par for the course with this build I had little idea what I was doing and plowing on regardless
I would have loved to have access to some of the equipment I have now then as I could have made a pcb instead of all those wires stripped out of a long LAN extension.Comment
HI Dwayne you are a true engineer an a eletristion an does pwm signal stand for pusle width modulation signal ? an from the ( arduino ) what does that mean ? AN DO ?
an i bet your grandaughter thought all her chritmas's had come at once eh ? as all the workin in the merry go round is way out an beyond my know how brilliant work Sir an i'll show my wife jen when she gets up as no work due to lockdown as she loved it when she first see it
all best to you an yours PS an i bet you had fun soldering all those led's up to their resistors as i do a fair amount of this type of modderling on my warship models as i light them up for shows all working from R/C
chris an jenComment
