Trumpeter LCM 3 - radio controlled
Posts
  • boatman
    • Nov 2018
    • 14498
    • christopher
    • NORFOLK UK
    #16
    HI Peter did you get a R/C 2.4 gig for this LCM ? an did you get it set up to the RX as they have to be binded an in some sets it can be hard to set up as my one of my friends had a job to set his up I had the chap in the model shop do mine an you can now get micro servo's just right for a model like this
    chris
      I'm watching with interest.
      • Wookie2486
        • 233
        • Marty
        • Yeovil
        #18
        Peter do you mind if I join John in the front row this is gonna be interesting.
        Marty
          • 22771
          #19
          Nice work with the motors.
          • Peter Gillson
            • 2594
            #20
            Evening folks
            Brad - I think. May have caught some of tht series, if it is the one I am thinking about he had a working helcopter on it!
            Chirs - a visit to my local model shop has resulted in my buying a 6 channel r/c set! A bit OTT but the 2 channel options were some of those trigger hand sets designed for cars more than boats or a Futaba set. The 6 channel set was only ยฃ3 more than the Futaba, it comes with a second receiver which may be useful since if this works I may have a go at the slightly smaller LCVP.
            Welcome Ralph and Marty
            Ian - thanks, I am quite pleased, the prop and motor shafts look aligned.
            I have added the fittings for the 2 rudders - simple vertical tubes out of brass, fixed with Araldite:
            For the rudders I used the kit parts glued to 1mm wire. I was not convinced about how strong the join would be so I used some thin metal (ex tomato paste tube), wrapping it around the rudder and the plastic and wire.
            Now I an just waiting for the speed comtroller to arrive before I can start to fit the R/c in place .
            • boatman
              • Nov 2018
              • 14498
              • christopher
              • NORFOLK UK
              #21
              OK Peter lookin forward to seein it sailin as it will be sailin way before my tiger an im following your build with delight
              chris
              • JR
                • May 2015
                • 18273
                #22
                Peter.
                This is all very interesting, moving back a couple of rows when the wet tests starts.
                John .
                • Steve Jones
                  • 6615
                  #23
                  Totally missed this one Peter. Will keep the umbrella up over JR in the cheap seats. Good luck
                  • scottie3158
                    • 14214
                    • Holbeach
                    #24
                    Peter,
                    An interesting build, I am watching from the cheap seats.
                    • Mr Bowcat
                      SMF OG
                      • Dec 2016
                      • 4606
                      • Bob
                      • London
                      #25
                      Also just seen this thread Peter. Looking forward to the build.
                      I'm hiding behind Steve & Paul, I so detest wet clothing.
                      Si vis pacem, para bellum.
                      • Peter Gillson
                        • 2594
                        #26
                        John - welcome, sit anywhere as long as you can reach me with the life belt.
                        Steve - I'm sure John will appreciate the cover
                        Paul - you are welc0me to share Steve brolly
                        Bob - if it sinks I'll try to make sure it is the other end of the pond.
                        Hopefully the speed cpntroller will arrive before the Easter break, in the meantmie, back to sculpting ...
                          Originally posted by Peter Gillson
                          Evening folks
                          [ATTACH=CONFIG]n1090783[/ATTACH]
                          [ATTACH=CONFIG]n1090791[/ATTACH]
                          Could you not just use 'tank steering' using a couple of modified servos?
                          • Peter Gillson
                            • 2594
                            #28
                            Rex - this is where my knowledge, or lack of it shows, but if have two servo motors then surely each would need their own speed controller?
                            Peter
                            • Peter Gillson
                              • 2594
                              #29
                              Now that Euro is over I can get back to this project. I have dry fitted the steering servo and steering gear as well as the two motors.
                              Tomorrow iโ€™ll add the radio gear and finalize all of the screws and nuts, at which point she should be ready for a test run.
                              Unfortunately, or fortunately, our pond is out of bounds due to these visitors - 10 duckings.
                              • Peter Gillson
                                • 2594
                                #30
                                setting aside other projects I decided to plough on with this one and finish it.
                                The first photo is of the radio gear - it all fits into what was the engine room on the full sized craft:
