1/72 Revell Flower Class Corvette
Posts
    Hi all,
    It's back to ships after a sojourn into the world of aviation modelling, namely the 1/72 Flower Class Corvette. I bought the kit about 3 years ago, and have been collecting the Great Little Ships photo etch for this model. As I now have it all I will be starting a build. As there is a lot of PE and each one is a kit in itself, I will be posting the PE as I use it.
    [ATTACH]300647[/ATTACH]
    • 18271
    You are going to have fun with that. You are going to solder the large parts I take it. Tried CA on mine and things didn't go to well.
    I will follow this from a distance. It will great to see one finished.
    • Steve Jones
      • 6615
      Graham
      My Grandfather served on HMS Godetia during WWII which was a flower class corvette so I will watch on avidly. Good luck
        Yes, I will be soldering the large parts. I have just ordered the solder and flux and reading up soldering techniques. I might even try to solder the smaller parts as well.
          • 18925
          Great, HMS Compass rose, star of one of the best British WW2 films...Iโ€™ll follow this with interest...
          Tim
          • Wouter
            • 742
            Good to see another ship appear, will be following with interest!
              Here is an update. I had hoped to post a picture of the painted hull, but I've been suffering with dry tip of the airbrush, so much so, I nearly threw the airbrush away. But instead I ordered some Liquitex flow aid. The hull is 85cm long. The propeller and scuttles are the first of many PE parts to be used.
                I've had this in my stash for years, I can't think of a place to display it! I'll follow this with interest!
                  I see that Revell have rereleased this in their 'technik' range.Same plastic, but it has an electronics package with loads of lights, and rotating radar scanner - at an eyewatering cost of ยฃ179!!!!!!! No idea which market this is aimed at....................
                    I noticed that as well. I agree it is very expensive.
                      Here is an update. The white I used to paint the hull was a pain to spray as it kept blocking up the nozzle of my airbrush, the other colours used were OK, so I ended up hand painting the white.
                      The next set of PE. This is the deck an fitting set. There are a lot of white metal parts to this as well the deck.
                        Graham,
                        white paints are always a pig to spray. if you thin it too much, then it won't cover, neat, and I find it clogs the nozzle very quickly - something to do with the chalky composition. I make a concoction of acrylic white, satin varnish, and retarder + water, and this is shaken for 5 minutes, and only applied 1/2 airbrush cup at a time, before cleaning, and another 1/2 cup - it takes longer, but it doesn't choke the nozzle!
                          • 15733
                          Hi Graham
                          Sorry to be a bit late in for this. These large ships are a lot of work but build into stunning models. I saw a completed one at Telford last year. Looks as if you are off to a good start. I shall be very interested in how you get on soldering the etch.
                            • 22771
                            I too am late Graham, but a cracking start, and all that PE, I'm joining in and watching this.
                            • Steve Jones
                              • 6615
                              Great update Graham. Any issues with the hull join?
