Placing compressor on the floor?
Posts
  • BattleshipBob
    • 6785
    • Bob
    • Cardiff
    Afternoon chaps
    In the modelling room I am finally going to leave the compressor set up as security will be very good.
    It's going to be on the concrete garage floor, now should I put it on top of something else?? Only concern I can see is draining the moisture trap, knees are not what they use to be lol.
  • adt70hk
    • Sep 2019
    • 10400
    Good question.... Mine is on the floor in the kitchen...but I don't have a choice..... Would be interested to here what the experts say!
    Thanks for asking.
    • Mark1
      • Apr 2021
      • 4156
      I would put it on a rubber mat,may help with vibration through the floor if any ,other than that only your knees know the answer!
        A doormat would do fine - just make sure that the vulnerable bits ( regulator/moisture trap/air hose ) aren't hanging out, just waiting to be kicked!
          • 18884
          Iโ€™ve only ever had mine set up on the floor. I do place it on an upside down square of carpet (off cut) so it doesnโ€™t damage the flooring, though that wonโ€™t be an issue for you. A carpet square would cut the noise transmission down a bit as will. I set the compressor to a high pressure and feed a secondary pressure reducing valve mounted on the airbrush holder so I can easily change operating pressures.
            • 15646
            My set up is the same as Tim's except that instead of carpet my compressor is on a rubber mat.
            I always release the pressure at the end of a session by removing the drain plug at the bottom of the tank. I then leave it out until the next time I airbrush. My thinking is it allows any moisture in the tank to drain/evaporate.
            • dave
              • Nov 2012
              • 1828
              • Brussels
              Mine is on the floor in the apartment, mounted via rubber washers to a wooden base, which has rubber feet to try and reduce vibration noise, neighbours underneath have never mentioned noise.
              • adt70hk
                • Sep 2019
                • 10400
                Same here..... And there's always moisture to some extent or other.
                  • 18264
                  A couple of layers of an off cut of rubber underlay for carpets should keep it quiet. As for the knee's up on a shelf us the best way round that one. The compressor not your knees.
                  • stillp
                    • 8086
                    • Pete
                    • Rugby
                    I have a couple of bits of wood under the feet of the compressor so I can reach the drain valve more easily.
                    • outrunner
                      • Apr 2019
                      • 2420
                      Mine sits on a bit of blue insulation foam.
                      Andy.
                      • BattleshipBob
                        • 6785
                        • Bob
                        • Cardiff
                        Thanks Gents, a goldmine of info there!!
                        I will have some spare insulation left over from the room!!
