Chrome, off or on?
Posts
  • outrunner
    • Apr 2019
    • 2420
    Chrome, off or on?
    I have a 1.24 Ford pickup truck that I intend to practice weathering on, actually, it's still in the box. Question is, should I strip the chrome off the wheels, mirrors and grille and paint them silver or just try weathering over the chrome. Rookie question I know, but if you don't ask...........
    Andy.
    • 18881
    I would strip them, clean up the mould lines that will be on the part, prime the parts gloss block, then spray them with Alclad II chrome. However, Iโ€™m a bit obsessive and donโ€™t like the appearance of plastic chrome....
    • PaulTRose
      • Jun 2013
      • 6442
      • Tattooine
      what sort of weathering?
      you will find a lot of things will not 'take' to the chrome easily
      Per Ardua
      • outrunner
        • Apr 2019
        • 2420
        I would like to make it look like it has travelled on a dirt road, dust, mud etc.
        Andy.
        • Mini Me
          • Jun 2018
          • 10711
          I'm with Tim on the Alclad II. It will give a much more realistic appearance and would definitely take to weathering better than the tinny stuff the manufacturers splash on their sprues. Rick H.
            • 22769
            I would take the Chrome off
              • 15638
              Hi Andy
              I would strip the chrome. It doesn't look right on models and as Tim says the part can be cleaned up and the fit checked.
              Alclad 2 is lacquer based and so smells and needs handling carefully. If you intend to heavily weather the model you might consider a more user friendly chrome paint - perhaps Vallejo or Darkstar. Not as "chrome" like but may be ok under weathering.
              • outrunner
                • Apr 2019
                • 2420
                Thanks for all the tips guys, chrome off it is.
                Andy.
                • Mr Bowcat
                  SMF OG
                  • Dec 2016
                  • 4592
                  • Bob
                  • London
                  Like the other guys, I'm generally an advocate of strip the chrome with bleach and re-paint. Having said that, I recently built an F50 from Tamiya, the chrome on the wheels wasn't that bad so I just gave a light spray over with smoke and I think they came out OK, pic below has the original wheels on the left, and the smoked wheels on the right. I guess it depends on how bright you want the chromework.
                  I should add, I only did this with the wheels, the exhausts were stripped and repainted.
                  Si vis pacem, para bellum.
                  • outrunner
                    • Apr 2019
                    • 2420
                    After asking the question about chrome I decided to try removing it from the wheels, bumpers and mirrors on the pickup kit.
                    Chrome.
                    [ATTACH]371544[/ATTACH]
                    No chrome.
                    [ATTACH]371545[/ATTACH]
                    I could not believe how quickly the process took, from dipping them in the bleach to washing and drying them must have took all of 3 minutes, great result and a good lesson from you guys, thanks for all the advice.
                    Andy.
