Dulling down paint finish.
Posts
    I have a 1:50 scale diecast bulldozer that I want to give a light weathering. I want to dull the paint finish a little to take the shine out of it.
    Anyone have any tips?
    Cheers.
  • flyjoe180
    • Jan 2012
    • 12356
    • Joe
    • Earth
    Try a flat/matt varnish coat?
      That's the way to go
        Will it take to a smooth gloss pain finish?
        • flyjoe180
          • Jan 2012
          • 12356
          • Joe
          • Earth
          Yes it will cover a gloss finish. A model is usually painted then gloss coated to apply decals and weathering, and then that is all sealed in using either another gloss coat or a flat/matt varnish. The varnish will work on gloss paint without the gloss varnish too.
            Thanks Joe, I will get some and try it out on the underside where it cant be seen before going all out.
              I've had good results with testors dullcote,comes in rattle can or bottle
                Take a look at this thread Martin.
                There are some interesting photos that can help you.
                http://www.scale-models.co.uk/community/threads/unofficial-kids-toy-remodelling-build-thread.14314/page-3#post-200388
                  Martin if you want a really dull finish then Vallejo Matt finish.
                  It is duller than their matt finish paints which are dull.
                  For WW11 aircraft I have used this through out and gives a very authentic look. You only need one coat even if you have applied gloss varnish for decals.
