SimonT - Hobbyboss 1/35 Russian T-18 Light Tank
Posts
    Looking better now, I think. Then again, Iโ€™m not a fan of models with obvious highlights and shadows, even though I think they often do look better if they have some.
      Well I thought the first was perfect Simon.:disappointed2:
      • SimonT
        • 2824
        #108
        Cheers Steve - definitely overdid it with the first try. Going to have to be a lot more careful next time I use that set of paints and remember that less is best :hugging-face:
        Thanks Mick
        Jakko - the fact that items exhibit highlights and shadows is what helps us determine the 3dโ€™ness of what we are looking at so personally I think enhancing the light and dark to offset the small size of the models has a place. Does help if it is not overdone of course
        John - sorry but it looked even worse in person. Far too much contrast between dark and light. The โ€˜shineโ€™ as they label it is not far off white so needs to be used sparingly - I was way too heavy handed with it
        Gave the whole thing a coat of Brown for Dark Green filter which has helped tone things down a bit further
        Have just finished adding some red stars on the turret
        First I did a test spray - stencil taped down
        Removed the needle cover and wound down the paint and air settings so I was getting minimum of paint spraying
        I used some Tamiya Matt red straight from the bottle - need to spray as dry as possible to reduce the chance of paint creeping under the stencil
        Test worked so onwards and upwards - clean the stencil with thinners and then tape it down on the turret
        and success
        The right side was a bit tricky as the stencil wouldnโ€™t sit down flat due to the hatch
        Had to angle the A/B away from the gap so the paint didnโ€™t blow under
        Have found that the Air Viper is not the easiest to clean due to the paint cup being an integral part of the body
          You made a very good job of it Simon, esp with overlapping that hatch hinge plate.
          Never heard of an Air Viper before ?
          • SimonT
            • 2824
            #110
            Cheers John
            One of these:
            AirViper
              I know, thatโ€™s why I said I think models do look better with them, but that I think they shouldnโ€™t be obvious. Too many models you see have such extreme highlights that the model looks painted rather than realistic, IMHO. Iโ€™m sure there are lots of people who like that, but Iโ€™m not among them I also suspect a lot of modellers paint their models like that because this is the way award-winning models are painted โ€” except that they then (probably subconsciously) exaggerate the finish in a way that the really good painters donโ€™t.
              I just realised that a probably very good comparison is typography, though I doubt most people will understand what I mean by that Essentially, really good typography takes a lot of effort for something that nobody except typography geeks experts will notice. OTOH, bad typography is something that almost everyone will notice, even if they canโ€™t put their finger on what is wrong with what theyโ€™re reading. (Making bad typography is easy, BTW: use Microsoft Word, for example.)
              • Steven000
                • Aug 2018
                • 2830
                • Steven
                • Belgium
                #112
                Looking good Simon :thumb2:
                Cheers, Steven
                • David Lovell
                  • 2186
                  #113
                  Not that I can talk haven't used the airbrush for a year or so but looks ok to me I found you had to over exaggerate so when you applied the filters it all comes together nice under state it and you think was it worth it, although I use filters on the paint job and washes around nuts bolts and hatches etc looking forward to the finish.
                  • Si Benson
                    • 3572
                    #114
                    Morning Mr T,
                    Nice work on the stencilling. They can be tricky to use but think Youโ€™ve nailed it :thumb2:
                    Iโ€™m another that prefers to over egg the highlights on the assumption that further weathering will mute the effect.
                    • minitnkr
                      • 7576
                      • Dayton, OH USA
                      #115
                      Sooooo much better than decals! Some excellent finish work. PaulE
                      • Steve Jones
                        • 6615
                        #116
                        I agree Paul. Nice work Mr T. Will be practicing with mine soon
                        • SimonT
                          • 2824
                          #117
                          Thanks one and all - the stencils do look good if you get them right. Luckily this time it worked out ok
                          Low pressure and paint as dry as possible so that it doesn't wick under the stencil and build up the coverage slowly
                          it got the first wash of 'Dark brown for dark green' last night - this is it when still wet
                          I left it drying for a few hours then removed a lot of it from the flat surfaces with little foam sponge make-up wotsits
                          It will get some more focused washing around the details once the initial layer has dried
                          • scottie3158
                            • 14257
                            • Holbeach
                            #118
                            Simon,
                            Great work the wash looks good.
                            • SimonT
                              • 2824
                              #119
                              the rear of each sponson has one of these rings (door knocker?)
                              I managed to ping the right side one off into oblivion with the paintbrush
                              so had to make a replacement - will need to paint it and blend to match surrounding paint
                              this is what it currently looks like after a few layers
                              made a start on the tracks using Tamiya flat earth as the base colour
                                Beautiful painting Simon - the stencils certainly give an authentic look.
                                Won't comment on shading except to say that it's down to individual taste. If you like it, do it.
