Flip!! That must be huge. I got a 1/72 for my birthday and the wingspan in on that is c 43cm...
Tamiya 1:48 Lancaster
Today I masked off the aircraft which took a fair while using the tamiya 6mm and 10mm tape I had left and just managed to get it all done.
As can be seen the whole airframe has been sprayed black primer and also the bottom has been sprayed flat black and varnished in the hope that it will assist paint adhesion when removing the masking tape.
Sprayed a coat of flat earth and have them shaded panels to try and break up the large areas and give them a little depth.Attached FilesComment
Sprayed a coat of flat earth and have them shaded panels to try and break up the large areas and give them a little depth.Comment
It's the first big model I've ever sprayed and was trying to give depth to it rather than my normal 1 shade. I've used the Hataka red top flat earth for that and it seems ok. Will varnish tomorrow and then mask for camo Tuesday when I've sourced some panzer putty.Comment
My mask arrived today, photos attached.
All went well till it came to fit it. I assumed the lighter brown is sprayed first, as I did. Wrong, the mask is for the green sections and so is useless. I considered reversing camo but it would bug me too much.
Masked with a pack of blue tac and masking tape, which I should have done to start with really.
Will spray later, too annoyed now.Comment
All said and done Iโm still undecided whether the camo looks better with a slightly feathered edge using blue tack anyway. Sometimes it looks a bit to sharp with the camo mask.Comment
Howโs the Lancaster going, did you manage to Complete it over Christmas or have you taken a short break?Comment
So after a long long break I unearthed a bag of enthusiasm today finally and took the Lancaster off the shelf and did a little more.
I attempted a gloss varnish. Didn't go well and didn't do a lot so I gave up and started decalling. Difficult tbh. Not being experienced and this being the biggest kit I've done I found them not a great fit and just too big. I have been using softener and setter but it's still not as good as I'd like.
Another issue when dry fitting turrets is that the pre painted ones dont match. No surprise I guess.Attached FilesComment
Finally managed to attach these without it crashing![ATTACH]426204[/ATTACH][ATTACH]426205[/ATTACH][ATTACH]426206[/ATTACH][ATTACH]426207[/ATTACH][ATTACH]426208[/ATTACH]Comment
