Meanwhile, somewhere in Europe
Posts
  • Neil Merryweather
    • Dec 2018
    • 5197
    • London
    #46
    That wood is excellent at representing the rock :thumb2:
    • adt70hk
      • Sep 2019
      • 10416
      #47
      Coming on nicely Gerry.
      ATB.
      • GerryW
        • Feb 2021
        • 1757
        #48
        Quick shot of 'Hy-Cote' high build car primer - shows up some points, but gives an idea of how it's going to look - will need 'detailing' with different stratas.
        It's a 'blast from the past' can remember many years ago (before shops started selling 'scenery' and only sold the one bag of 'foliage') that bark and wood were used for railway layouts (and living around here - it's free! :thumb2: )
        ATB.
        Thanks Andrew - though the 'test' is still to come with the 'water feature' - been swotting up on techniques, but the test will come when I try it for the first time (wondering how many will end up in the bin!)
        • GerryW
          • Feb 2021
          • 1757
          #49
          Yep, definitely looking better with the second bit done, just need to retrieve the bit that fell through the hole now!
          • JR
            • May 2015
            • 18273
            #50
            Gerry certainly has the look of rocks alright.
ID:	1148374Click image for larger version
            Photos for discussion purposes only.
            • scottie3158
              • 14211
              • Holbeach
              #51
              Gerry,
              Looking good really nice work on the "Rocks"
              • GerryW
                • Feb 2021
                • 1757
                #52
                [ATTACH=CONFIG]n1148374[/ATTACH][ATTACH=CONFIG]n1148375[/ATTACH]
                Gerry,
                Thanks both, decided to 'smooth off' the rough patch at the top
                I'll give it another squirt of primer tomorrow and see what it looks like, but hopefully that end's ready for painting - just the rest of it to do!
                • GerryW
                  • Feb 2021
                  • 1757
                  #53
                  HOW THE HECK DO I KEEP POWDER FROM BLOWING AWAY:fearful:
                  Trying to get the 'road' laid, or at least start it, but I've tried to mix with glue and 'paint' it on - just balls up on the brush, tried putting down a layer of glue then sprinkle on top and rolling - just the bottom layer sticks, now trying soaking with hairspray, but not holding my breath! All I want it to do, is to 'hold' until I can soak it with paint (which should hold it afterwards)
                  • GerryW
                    • Feb 2021
                    • 1757
                    #54
                    Success! At least it's held while I gave it a squirt of primer! :thumb2:
                    • JR
                      • May 2015
                      • 18273
                      #55
                      That is a problem Gerry.
                      You could try a spray with some water/ washing up liquid ( wet water ) or isopol. Then while wet let the glue flow through it. The washing up /Isopol will break the surface tension and allow the thin pva to work its way. Then add a the dust/ debris with a sieve. The main trouble comes when you want to add just dust, being so fine it turns in like you've found a mud mess. May be a fine low pressure mix of thin paint will work ie Life Color's Dust
                      • GerryW
                        • Feb 2021
                        • 1757
                        #56
                        I seem to have found a way - needs a little bit more up the middle though - just to accentuate it, and the rest of the 'road' laid, bit more work on the walls - then it'll be time for me to see how well I've taken on board how to do water! Keep putting it off!
                        • JR
                          • May 2015
                          • 18273
                          #57
                          Looking good Gerry.
                          The only thing I would say about water is SEAL THE BASE AND SIDES WELL :nerd:
                          • minitnkr
                            Charter Rabble member
                            • 7546
                            • Dayton, OH USA
                            #58
                            Love wood as rock. Very convincing. Keep in mind the road and surrounding area is rock & smaller rocks. Not a lot of soil anywhere.
                            • GerryW
                              • Feb 2021
                              • 1757
                              #59
                              Looking good Gerry.
                              Other than this 'road' there's just two things that I've never tried, the 'water' and a campfire (with smoke).
                              Must admit that a few years ago, I'd have done the road with sandpaper/wet'n'dry and just painted that and not bothered about the center 'hump' along the road.
                              • GerryW
                                • Feb 2021
                                • 1757
                                #60
                                Sod it - just dawned on me how I should have done the blasted road - mixed up the road material with the PVA, and troweled it on!
