Centurion AVLB (slow build)
Posts
  • scottie3158
    • 14214
    • Holbeach
    #136
    Mike,
    Cracking work mate.
    • adt70hk
      • Sep 2019
      • 10419
      #137
      Mike,
      That really is stunning already.
      Great work!
      ATB.
      • Mark1
        • Apr 2021
        • 4156
        #138
        What a great build this is.
        • Graeme C.
          • 1605
          • Graeme
          • UK
          #139
          Looking good Mike.
            • 15733
            Stunning stuff Mike. I do find this inspires me to try to improve my efforts.
            On moulds like that I have had some success pouring in a small amount of rubber and then poking and scraping around with a cocktail stick to ensure the rubber gets into all the corners and then topping up.
            • JR
              • May 2015
              • 18273
              #141
              Oh Jim , makes me want to take up kitting . Some people are just too good :nerd:
              • JR
                • May 2015
                • 18273
                #142
                Wibble your definitely in a league of your own .
                Remember not all track photos are the same , you've not seen mine !!!!!
                Wobble .
                • Scratchbuilder
                  • Jul 2022
                  • 2689
                  #143
                  Jim,
                  Did all that, tapped it to get the air out and put it in the airing cupboard so the warm air would get the bubbles to rise to the top. Will take a deep breath and give it another try later.
                  Mike.
                  • Scratchbuilder
                    • Jul 2022
                    • 2689
                    #144
                    Update,
                    So, tried another mould after removing small parts from the master. Fairly trickled the rubber mix into all the small gaps first, and used a cocktail stick to make sure the mix was in all the corners. Then when it had set I removed the master and did a check and all the shape was there. Then I cleaned up the outside of the mould itself to get rid of any excess rubber that normally finds its way between the Lego bricks I use as the outside support. Flushed with success I then set too with the resin for the first casting, first pouring it in and making sure all the tiny gaps were filled, and with a final scrape across the top of the mould to get rid of the excess resin it was put aside to dry. So it set and when removed looked like it should, but when cleaning up I noticed one side was smaller than the other, checked the master and that was ok, so cast another nad the same result. So another casting was done and that has come out ok, and all is as it should be. But then I looked at the resin casting process and the material to be used and decided that for the small amount of resin used , the time taken and the mixing cups wasted, it would in fact be a waste of time and effort. When you take in the time to clean up the mould, mix the resin, pour it in the time you have before it sets, then the drying time and finally the clean up time, I could in fact have half of one scratch built or even built and still be left with the additional parts to be added - so that is where I am now cutting and glueing all 16..... And as it is not a race, then I can take a break and do additional work on my other build.
                    More later
                    Mike.
                    • Scratchbuilder
                      • Jul 2022
                      • 2689
                      #145
                      Forgot to add to the update, the fuel filler caps are now done, painted and in place...
                      Before and after a splash of paint....
                      Mike.
                        Those are, what, 4โ€“5 mm diameter? Impressive work once again
                          • 15733
                          Originally posted by Jakko
                          Those are, what, 4โ€“5 mm diameter? Impressive work once again :smiling3:
                          Not really Jakko, he has a magic shrinking ray gun!! :smiling5::smiling::tongue-out3:
                          • Scratchbuilder
                            • Jul 2022
                            • 2689
                            #148
                            They are 5mm over the length.
                            • JR
                              • May 2015
                              • 18273
                              #149
                              Nice Wibble .
                              • Scratchbuilder
                                • Jul 2022
                                • 2689
                                #150
                                Update,
                                So been plodding along with the centre plate/frames,
                                On the top bazooka plate you will see that the third one has the support brackets in place, the 'T' shapes are the backing plates. These are only fitter to the rear four, and all the rest are just normal lengths. The reason for the cut outs was to allow mud and debri to be run out the sides.
                                These are made from aluminium strip and bent to shape 3mm length...
                                A close up...
                                And the build jig - rough and ready but does the job...
                                More later,
                                Mike.
