Scotties big Zundapp
Posts
    • 18925
    Tim,
    Your right it does look strange I think I need to tone down the exhaust a tad but, the frame will look older when I have finished.
    Thanks Mark
    Tone down the frame first :thumb2: The bike probably just needs a bit of dust to tie them together once you have…..
    • scottie3158
      • 14214
      • Holbeach
      #257
      I agree mate the weathering will make the frame darker as well as loads of dust.
      • scottie3158
        • 14214
        • Holbeach
        #258
        I have continued detailing some of the smaller parts. I am waiting for some brass rod before I can start on the linkages.
        The riders foot rest has been cleaned up and a bolt head added.
        The pillion passenger footrest has also been detailed with bolt head detail plus the pivot pin and finally the foot peg was drilled out and a piece of tube added.
        Finally for today the fuel tap and pipe work was tweaked. the plastic replaced with wire and plastic tube and the fuel tap made from copper wire.
        cheers
        Scottie
        • outrunner
          • Apr 2019
          • 2420
          #259
          Detail work to be proud of Scottie.
          Andy.
          • Neil Merryweather
            • Dec 2018
            • 5198
            • London
            #260
            Insanity!
            If I ever get round to doing my BMW , I am going to have to forget I ever saw this thread :fearful:
            • The Smythe Meister
              • Jan 2019
              • 6248
              #261
              Insanity!
              Ditto mate
              • scottie3158
                • 14214
                • Holbeach
                #262
                Andy.
                Thanks Andy, very kind of you.
                Insanity!
                Neil not at all mate if I can do it so can you, but thank you.
                • scottie3158
                  • 14214
                  • Holbeach
                  #263
                  Ditto mate :smiling3:
                  Ditto what I said to Neil :smiling:
                  • scottie3158
                    • 14214
                    • Holbeach
                    #264
                    Luckily for you there is only one picture tonight. The prop shaft and hydraulic pipe for the rear brakes were appalling, moulded so far off centre that they would have been so thin when cleaned up. So it was easier to make them the prop shat is some ally tube with ally collars cut to size and the pipe work a mixture of the kit part punched nuts and wire.
                    cheers
                    Scottie
                    • Allen Dewire
                      • 4741
                      • Allen
                      • Bamberg
                      #265
                      Knit one, Perl two. Knit one, Perl two. Knit one......Don't care if this damn scarf takes 6 months to make with thread!!!
                      Seriously Bro, this is so, so good and soooo you!!! The pic of this on the bench, says it all. Love it!!! BTW, what wire are you using to do the linkage and fuel lines? It looks like it takes bends really well and smoothly too.
                      Allen
                        • 15733
                        Quite simply superb. I like what you did with the decal - very good idea.
                        • tr1ckey66
                          • Mar 2009
                          • 3592
                          #267
                          Beautiful work, this just keeps getting better!
                          Paul
                          • scottie3158
                            • 14214
                            • Holbeach
                            #268
                            Allen
                            Allen, Thanks mate if your knitting is anything like mine it will take a year to do a row. The wire is just normal copper wire I have a selection of diameters and some with a coating and some plain, I have a pair of pliers that form a radius but tend to favour just bending round a suitable diameter.
                            Jim, Thank you matey really appreciate it.
                            Paul
                            Paul, you are to kind thank you.
                            • Mini Me
                              • Jun 2018
                              • 10711
                              #269
                              Nice thing about copper is it's malleability,so there isn't much, if any, "spring back" when forming or bending it.
                              • scottie3158
                                • 14214
                                • Holbeach
                                #270
                                Rick,
                                Very true I collect wire from all sources old flex etc I also have some steel wire of various gauges but I can't remember where I got it.
